Price : 3,500 Rupees. Can deliver in Islamabad and Rawalpindi but if you buy in another city you will have to send the money + shipping in advance.
What I'm Selling :
- GPS tracker unit only used a few hours
- Tracker Battery
- Tracker USB charging cable (charger not included, can be charged by any USB charger)
- Tracker manual with full specs and instructions on how to operate
Delivery:
I can deliver for free in Islamabad and Rawalpindi. If you want to buy in another city you can pay for the shipping + payment of the device and I can ship it to you.
Notes:
If you want to get it permenantly installed in a car you will have to get it wired by a car electrician. The pin of this charger is very common (like android charging pin but a little fatter like older android).
If you want to do it yourself you can just plug the USB cable into a car cigerette lighter usb charger and hide it in the dash board. You can also charge it at home with a mobile charger and put it in the car/bike when you are going out, then charge it when you get back home since it fits inside a pocket easily.
Features:
Build-in GPS personal locator
High sensitivity, new technology MTK GSM CHIP and Switzerland UBLOX GPS chipset
Protect car/ bike/ child / elderly / the disabled / pet etc
Location is sent by the unit via SMS. Works with all Pakistani sims. Sends back GPS co-ordinates as well as a google maps link to check location. It also sends back the current speed of the vehicle.
This has a built-in Mic and can be used as a "silent listener" without letting the theif know that the conversation has been listened.
Waterproof design, can be adsorbed in the hidden place of car
SOS button send out exact location for immediate rescue/action if being carried by a person.
Compact, easy to carry and hide.
Indication changes when power is on / off and if there is a GPS signal via red led light.
Support Micro SD Card for recording.
Can be setup to alert owner if Vehicle exceeds a certain speed.
Can be setup to alert the owner if Vehicle is moved from where parked.
Can be setup to create a "Geo Fence" where GPS alerts owner if Vehicle goes outside of selected areas.
Even if there is no GPS signal the tracker can deduct a location via GPRS/GSM.
GPS Accuracy is 5 meter.
Specifications:
ProductDesctription: Mini Global GPS Tracker
GPS Chip: UBLOX CHIP
Network: GSM / GPRS
GPS Sensor : Yes
GSM Frequency: 850 / 900 / 1800 / 1900 MHz
GSM/GPRS Module: MTK 6260
GPS Accuracy: +- 10 M
Battery: Rechargeable 3.7 V Li-ion Battery (Easily available in market, same battery as old Nokia phones)
Working Temperature: -20 to 55
Humidity: 5% to 95% non-condensing
Altitude Limit: 18,000 meters (60,000 feet) max
Velocity Limit: 515 meters/second (1000 knots) max
Acceleration Limit: Less than 4g
Dimension: 64 (L) x 46 (W) x 17 (H) mm
Weight: 50 g
