Guys I have Suzuki Every JDM 2007 model. The car runs fine when cold, but once it heats up the car starts to idle rough and losses acceleration at the stop lights. After a few minutes it starts running again, until the next stop light. Since the petrol has gone around 1/4 of the tank. The car doesn't have the above symptoms. But I did feel that the car was vibrating a bit on idle. So, once i reached home. I gave it maximum race, the car made some pop noise, and trembled harshly and then it won't turn on. After a few hours, I started the car again and it worked.
Could this mean that I need to change fuel filter or fuel Pump? I am not sure where the MAF sensor is located on every, but I did clean up using circuit cleaner the part I thought was MAF. Also, I cleaned carburetor with carb cleaner. But I didn't put anything in the fuel line. Still same symptoms. I usually go for petrol from either PS0, Caltex or Total. But my driver put the petrol in car from some unknown petrol station. I am pretty sure that car started troubling me after this.
Any guidance would be appreciated.
