Hi,
I have a Toyota Crown 2000 (JZS175) with 2JZ-FSE engine. The problem with the car is its engine slightly jerk on idle but not every time, and the same sort of issue occurs on high speed while leaving the accelerator pedal. The issue disappears as soon as the accelerator pedal is slightly pressed. There's no loss of power and no fault code. But exhaust smells like bad mixture.
So far, I have gone through below list of jobs:
1. Spark Plugs replacement
2. Ignition Coils replacement
3. Injectors checking and cleaning
4. MAP sensor replacement
5. Vacuum pipes replacement
6. Throttle service (tried with another throttle body but no luck)
7. Timing belt replacement
8. Catalytic converter cleaning
9. Fuel pump and filter cleaning
10. EGR cleaning
11. Vacuum Switching Valve replacement
The car is running on Hi-Octane and using Meguin 10w40 synthetic oil.
Appreciate if someone could direct me to an expert of these engines or someone who has faced same sort of issue.
created
Jan '24
last reply
Jan '24
- 29
replies
- 3.2k
views
- 11
users
- 10
likes
