Yes it could be the camshaft seal too (i did forget this) Good one!
Ok that actual pics you post do show a lot of oil accumulated, here is what you need to do before you can figure things out.
Go get your engine bay pressure washed specifically that area of oil and even from underneath the engine bay (pay the guy a bit more and while cleaning it as good faith jesture he will teach you how to clean your engine bay :))
Do not oil it or diesel it or whatever they spray on after the wash, just keep it dry and keep an eye open for things being pushed or pulled by wash pressure.
get it hand dried using clothes or whatever. Take it home and let it sit there to dry until completely dry.
then start the engine and look for the oil if it is visible, good place would be with lift or ramp so you can lift it up and have a view from underneath too, sometimes not all things are visible from the top.
With everything cleaning any new oil pouring will be visible, plus if you can get additive dye which is mixed in engine oil for better visibility and easy, to pinpoint the leak.
Hope this works for you!
