Thanks for the detailed reply.
Does CEL stand for Check Engine Light?And I think the EPS system has its own motor so as per my understanding it is not dependent on Car engine?Am I right?
The present shape Diesel Corollas have EPS installed in them.They too have 2C engine without ECU in the car.The EPS has its own ECU as per my knowledge.I know you are quite in into these things, so I shall be grateful if you find out, how the Indus has managed to install Electric Power Steering in the present shape Diesel Corollas without the Main ECU?If you can find out the diagrams of Pak Diesel Corolla with EPS?I am also looking into it, if I find anything I will let you know and take your advice.
