Hi, I wondered if anyone knew that if a 2003 vti oriel manual ecu can be repaired. There was a short circuit and stupid electrician removed a fused which kept blowing and made it direct. That small problem turned big with smoke from the engine wiring. I got wiring working again but the ecu doesn't seem to be working normally, there is no visible sign(No burning smell or burned circuit)though the circuit solding seems to be affected a little. IS it repairable?
And is it possible to use a automatic civic ecu.My mechanic said that he connected a auto one and started the engine it worked but I was wondering will it create some problem?
Thanx!
