A diesel engine is an internal combustion engine that uses the heat of compression to initiate ignition to burn the fuel, which is injected into the combustion chamber during the final stage of compression. This is in contrast to a petrol (gasoline) engine or gas engine, which uses the Otto cycle, in which a fuel/air mixture is ignited by a spark plug.
It operates using the diesel cycle (named after Dr. Rudolph Diesel). Diesel engines have the highest thermal efficiency of any internal or external combustion engine, because of their compression ratio.
Diesel engines are manufactured in two stroke and four stroke versions. They were originally used as a more efficient replacement for stationary steam engines. Since the 1910s they have been used in submarines and ships. Use in locomotives, large trucks and electric generating plants followed later. In the 1930s, they slowly began to be used in a few automobiles. Since the 1970s, the use of diesel engines in larger on-road and off-road vehicles in the USA increased. As of 2007, about 50 percent of all new car sales in Europe are diesel.
History
Rudolf Diesel, of German nationality, was born in 1858 in Paris where his parents were Bavarian immigrants. He was educated at Munich Polytechnic. After graduation he was employed as a refrigerator engineer but his true love lay in engine design. Diesel designed many heat engines, including a solar-powered air engine. In 1893, he published a paper describing an engine with combustion within a cylinder, the internal combustion engine. In 1894, he filed for a patent for his new invention, dubbed the diesel engine. His engine was the first to prove that fuel could be ignited without a spark. He operated his first successful engine in 1897.
In 1898, Diesel was granted U.S. Patent 608,845 for an "internal combustion engine".
Though best known for his invention of the pressure-ignited heat engine that bears his name, Rudolf Diesel was also a well-respected thermal engineer and a social theorist. Diesel's inventions have three points in common: they relate to heat transference by natural physical processes or laws; they involve markedly creative mechanical design; and they were initially motivated by the inventor's concept of sociological needs. Rudolf Diesel originally conceived the diesel engine to enable independent craftsmen and artisans to compete with industry.
At Augsburg, on August 10, 1893, Rudolf Diesel's prime model, a single 10-foot (3.0 m) iron cylinder with a flywheel at its base, ran on its own power for the first time. Diesel spent two more years making improvements and in 1896 demonstrated another model with a theoretical efficiency of 75 percent, in contrast to the 10 percent efficiency of the steam engine. By 1898, Diesel had become a millionaire. His engines were used to power pipelines, electric and water plants, automobiles and trucks, and marine craft. They were soon to be used in mines, oil fields, factories, and transoceanic shipping.
//youtu.be/http://www.youtube.com/watch?v=qDG6hwpou80&rel=1
