Salam to all. Just wanted to get some expert advise.
I have a 97 vti, and i swapped the engine because of a previously messed up block.
The engine installed currently is a D-15B as per the code on the block. After some research i have found out there should be 2 vtec solenoids instead of one (because this is a 3-stage vtec engine). To my suprise, either soleniod is not visible.
My questions is
1. whether if there is a D-15b engine without vtec.
2. If this was a v-tec, is it possible to remove the solenoid and the engine still running perfectly.
3. Can i install solenoids if available in shershah market?
4. Do i have to have the correct Ecu (P28/ P08) for peak performance. how to verify which ecu is installed.
Thanks so much.
created
Aug '08
last reply
Apr '10
- 48
replies
- 15.3k
views
- 1
user
- 14
links
