Hi Guys
Got a Vitz 2010 automatic transmission. Since last Friday I got the engine check light on. The pick up of the car went extremely low and there seemed to be an issue with changing gears and the RPM got very high when the car reached a speed of aroun 80-90 kmph. It seemed as if the car was stuck in 3rd gear from 0 - 100, low pick-up, after 40kmph it behaved normally but didnt change gears as expected and by the time it reached a speed of 90-100 the engine was roaring as if on very high RPM.
I got it checked, CVT filter was serviced, gear oil was changed and the car went smoothly for a day before the problem recurred. My mechanic suggests changing the complete gearbox which will cost me around 50K pkr.
Could there be some other issue, any fixes, someone else faced a similar problem.
