i have recently replaced my margalla's pump with guage, u r rite it originally came with mitsubishi pumps i have got two now due to a mechanic experiment
its kabli purchased 1 frm magzine line @ 1200 other1 frm shafiq mour @ 1500 which is working perfect now far better then local ones available @ 700-800rs i didn't knew that it came new @ 4500, the one 1 found was taiwan made not like genuine and the shopkeeper was asking 5500 for it with no warrenty finally decided 2 go 4 kabli 1 atleast they r original if not repaired, u can check it usage before fitting but suppling power and put a pipe in water tub if the flow is gud install it.
tips for keep it running is always keep some fuel in ur car and also consume within a month, dnt store fuel more than 2 months o/w fuel is expired
try 2 make a routine of running ur car on patrol daily or after 2-3 days dnt save too much @ cng
it will keep the car engine/pump healthy if u don't convert ur car on patrol more than 2-3 months ur fuel pump will b gone so take care.
pics attached for refernce, its old pump was last used 8 years back
dats y all rusted so had to replace it.
