[quote="abdul_wasay1, post:2, topic:446818, full:true"]
Your car door pins or locks (hinges), mirrors are loose. Get it repaired from kharadia. Go to some responsible denter get it check. Your back diggi lock may be loose. May have steering cloumn play. Also need front suspension work like steering column press, chimta press, godda noise in turning, if your car was too muck running then check the shocks oil leakage under the fender, if yes then buy new ones.
[/quote]
Thanks for your suggestions brother
