Let me try and explain in simple words .. people say i'm good in giving explanations, perhaps it is because all my life i've been a salaried person working under different bosses ..
.. anyway here it goes :
1000w = 1kw and if u use it for one hour you are billed 1 unit of electricity
with this in mind, calc units for anything you want to use
Billing : there are brackets (e.g under 300 units, 700units, 1000 units etc ) and there is type of connection like (peak and non-peak for 3phase digital meters and then the old analog meters) ... in the end it is number of units consumed in a months .. the bill could be as low as rs 3 per unit including taxes and as high as rs 23 per unit
a detailed explanation is given in one of the threads i created .. search in profile if u want to go thru it .. in case of querries do ask
