This SUV is manufactured by a canadian based company and is supposed to be the toughest SUV.
here are the specs on it: (H)
Conquest Vehicles | Vehicle Specifications
Weight: 13,000 lbs (5,896.07 kg) approximately
Wheelbase: 145" (3683 mm)
Height: 100" (2540 mm)
Length: 235" (6000 mm)
Width: 96" (2438 mm)
Ground clearance: 14" (355.6 mm) approximately
GVWR: 19,000 lbs (8846 kg)
Engine: Gasoline Engine: Ford 6.8L, V10
Diesel Engine: Ford 6.7L Power Stroke, V8 Turbo diesel engine
Horsepower: Gasoline Engine: 326hp, 462 lbs torque
Diesel Engine: 300hp and 660 lbs torque
Transmission: 5-speed TorqShift automatic
Chassis: Ford F550 Super Duty platform chassis upgraded to our specifications
Wheels: MPT Continental tires 335/80 R20 MPT81
Fuel: Gasoline or Diesel
Fuel Capacity: 63 gallons/238 litres (a larger fuel tank is also available as an upgrade)
Steering: Power steering
Brakes: 4-wheel disc with ABS
Air Conditioning: 2 units: Factory AC in-front cabin with auxiliary AC unit in rear
