Hello All,
I am silent reader of PakWheels from more than three years now, but never felt the need of sharing something or commenting upon, it was all so complete until yesterday when I made-up my mind to install a sub in my car.
The car is Toyota Corolla GLi '13 and running the default headunit Alpine CDE-1216 with stock front components and Sony XS-GTX6942 in the rear, both attached directly to the headunit. This setup is running fine so far but the newly installed upgrades are a complete turnoff.
After searching a few shops on Hall Road I decided to go for 1 channel Power Amplifier MRV-T6001 powering a 12' KENWOOD KFC-W3010. I didn't had time to search for reviews for the product I selected as my GPRS wasn't working there unfortunately (Screw Warid) but anyways, the upgrades were installed.
The first problem I faced was the sub wasn't producing enough sound as it was inside the sound test cabin of the seller although it is enough for me on loud volumes.
Second which I found latter was the sub is producing noise which is not audible in traffic but can clearly be felt when the surroundings are silent.
Installation procedure followed a direct 12v+ wire from battery running from the passenger side harness along with Remote wire & RCA connector wires to the boot where the setup was installed, the ground was attached to the left most screw holding the back seats (I know it was a weak spot but the installation guy insisted it's good enough for this setup).
Amplifier costed my 12K & Sub 4.5K & all things used were brand new.
Wires used: +12v Stringer, ground Pure Copper wire, an ordinary remote wire and a bit thick wire for RCA connectors and Sub cables.
Base-tube: An ordinary tube bought from Hall-road for 1.2K
I would highly appreciate if anyone can help me find the real problem along with a nice place in Lahore to proceed further with the installation as I want my amplifier to be fixed at the back panel (That grey card covering the hollow spaces of rear seats - I'll need a plywood for that purpose?) and suggest any alteration in the installation.
I'm not a music freak and a bit old equipment for me is fine but if these things sucks (although the rear speakers & mono amp shouldn't) I'll be happy enough to swap them with better goodies if you can convince me?
Waiting for your replies and positive feeback.
Regards,
Osama
