Can I clean Oxygen Sensor without removing it.? If there is any method then kindly share..Further If Oxygen Sensor badly corroded and still not remove from last 3 years then what will be the procedure of removing it without damage it and any other components. Thanks in advance.
Spray Kerosene Oil or WD-40 on the O2 sensor, and leave it for a few hours. It should come loose. There is no way of cleaning it without removing.Best way to clean it is to remove and clean in an ultrasonic cleaner.
Yeh aaj kal HHO Machine or ultrasonic cleaning method jo complete engine k liye hota hai woh kia cheez hai kia woh best hai kia Pros and cons hai
HHO cleaning is done for cleaning intake manifold. Ultrasonic cleaning can be done for spark plugs, fuel injectors, O2 sensors, jewelry and dentures
HHO cleaning se jo andr Piston + valve hote hai woh b clean hn gye kia
