First and foremost check your water pump and thermostat valve. If they're also corroded, you will need to replace them too. Otherwise, your car will still overheat on coolant too.
Use Caltex Coolant, buy 2 bottles and mix with 2 bottles of distilled water in a bucket, and then add to your radiator and the reservoir(after cleaning it too, of course).
It has a life of 200,000kms, so its the best.
