Sep 2012
1 / 42
Sep 2012
Dec 2019
Dear all
i was away on a official tour for one week and on my return i noticed a strange problem in my car, when in the morning i started my car everything was normal but when i pressed brakes and put the car in R the car significantly started vibrating, i drove little bit no vibration in forward movement and then even no vibration in reverse everything was normal this same thing was happening from the last 2 days. i personally feel there is something wrong with the braking system as brakes are not releasing evenly and making vibration in the tires you can call it STICKY brakes.
rest no issues in braking or driving or any other thing everything is normal. pls comment on above issue what are the things which i need to get checked or fixed.
  • created
    Sep '12
  • last reply
    Dec '19
  • 41
    replies
  • 8.4k
    views
  • 15
    users
  • 4
    likes
  • 4
    links
does ur car vibrate on P or N? coz i remembered my dad reborn prosmatic had this vibration problem last yr...turn out it one of the mount seal was worn out/broken....i ve heard most of the reborn promastic had these issue....i hope ur car prob is not same
Bro only in R And only in morning that's the most weird part I personally think brakes are the culprit but will visit mechanic very soon.
Sent from MIS iPhone using Tapatalk
ur cars enigine hydrolic mount is broken
replace that mount this problem ll solved
orignal mount @ 12000
thai mount @ 8000
china mount @ 4500
local desi mount @ 2500
i prefer u to add orignal 1 that is the only which works for few years
reat all others ll again broke with in 2-3 months
yup its the mount, had the same problem a while back. Happens because of the lovely condition of our roads here
But Yar y only in the reverse and only in the morning - if mount is broken the car should vibrate in all conditions reverse forward etc
i hope its not the mount problem...maybe its brake problem....if it doesnt vibrate the whole day mean its something else....only in the morning tht too on Reverse is strange
14 days later
problem is back :frowning: - its so irritating i dont know what to check and which stupid is making this problem. i personally thing that there is something wrong in clipper pistons, help me guys !!!!
engine hydraulic mount is also gone very little gap remaining in the hydraulic system :frowning: and its dam expensive honda is giving it for 12500. . any good cheaper solution available ? ? ?
cheaper way is to get thailand made mount,u can go to reliable spare part shop.....maybe u can get genuine mount in less price than Atlas Honda or other brand of the same mount in half price of wat honda quote
sooner or later you may need to change the all 4 mounts in your car 1 each for right & left 1 each for transmission rear & front for better performance stick to OEM mounts so stability of car is not compromised
ADVERTISEMENT
15 days later
guys help karo i am unable to find the problem and even mechanic is saying that nothing is wrong but kaya karron still having same morning vibration only during reverse. . !!!!!!!!!!!!!!!!!!!
did you even read it..........
its says [I]''my car started showing vibrations during cold start and it was really bad and vigorous while doing reverse and it use to go away after say initial 1-2 km run.''
[/I]then[I] ''Vibration completely gone and more effective braking now''
Source: [/I]8http://anaphoral.blogspot.co.uk/2012/02/honda-civic-engine-vibration-fix.html8
