do you think there is any market for Choppers from china as in the pic below.
*Engine: 150cc/200cc, 4-stroke, single cylinder, air cooled
*Starting kick start/electric start
*Max power 9.5kW/8,000r/min
*Max. torque: 8.0N.m
*Compressed ratio: 9.6:1
*Tank: 5L
*Drive system: chain
*Transmission 4-speed, manual clutch
*Rim aluminum alloy
*Wheel size: 70/70-15 (F), 205/40-14 (R)
*Wheel base: 1,860mm
*Ground clearance: 100mm
*Brake (front/rear): hydraulic disc brake (F), hydraulic disc brake (R)
*Max. speed: 80km/h
*Max. load: 120kg
*Range: 100km
