dont try to fix that pump ,,,,,, none of our diesel labs are capable to rebuilt that pump as per original specs,,,, and then calibrate it as per original specs,,,,,,, no way any one can do that here ,,,,,,, find the exact part number of that particular pump used in your engine and search for it in old parts shop ,,,,,, same pump used in many engines but with different fuel delivery setting and different part number,,,,, for example same pump is been used in 1C and 2C engine but they both leave factory with different part numbers and with different fuel delivery settings ,,,,,,, so part number is very important and also before buy check the seal on max fuel delivery setting screw ,,, if its tamper then leave it ,,,,,,,
