Jul 2020
1 / 4
Jul 2020
Jul 2020
Hi people. Hope you're doing great. So I've been searching for a good headlight bulb for my bike. Options are either LED or halogen. Bcz i want yellow light. So if i install a more wattage halogen bulb and connect it to 4amp battery with headlight relay, will it drain battery that much that i cant add other things or is it gonna be fine?
Also recommend bulbs in ur opinion. Bulb size: H6M
  • created
    Jul '20
  • last reply
    Jul '20
  • 3
    replies
  • 721
    views
  • 2
    users
CD70 headlight bulb glow direct from generator current so you don,t have to worry about battery...if you will use halogen it will not glow as much so better to stick with stock or you can use led but for that need to change in wiring because led runs from battery
It will run fine on battery but i think u don,t need to install relay need modification to be done in head light handi
