procedure to fire up a new catalytic converter.
1 pre - requisites.
Make sure engine has been corrected and fixed of all previous problems that caused failure of cat, e.g. misfire
make sure the unit is installed with no leaks.
Make sure the pre and post cat sensors are reliable (not weak or sending false info)
2 startup
start engine and hold at ~40%% of max engine speed - (e.g. 2500 rpm on a 6000 rpm redline engine) for about 15 minutes. - This heats up the converter and puffs up the thermal blanket around the core of the converter honeycomb matrix which seals it to the casing and forces all gases to pass through it rather than around it.
This procedure is only done once when a brand new cat converter is installed.
