I hope this is the right forum to post this question.
I am just starting to learn how to drive. One of the things I have noticed is that when I put the car into neutral gear it starts to vibrate but when press a little on the accelerator the vibration goes away. Is this normal or is there some thing wrong with my car. (Cuore)
get it tuned, its normal. race thori kam hai car ki. dont worry.
:S ... :s ... :s ... Race kam hai i agree ...
Ya thandi hoti hogi gari ... garam kerkay chalaya kero ...
And Its normal behavior dont be worry ...
yar mein to full garam karkay chalata hoon par pher bhi yehi hota hai. Aur yeh engine tuning bhi koi bala hoti hai
i think u need to set idle RPM, just take the car to any good tunning center... normal for CNG cars...
Goto mechanic and say him thori race tez ker do ... Zara see ... I will stop vibrating then ...
i think ya to gari thandhi hoti hogi ya engine thora sa kaharak gaya hoga
some times it can be due to broken engine mountings
bro, first of all check all plug cables, if one of them is loose it means one of ur cars piston not working, it may cause vibration, pl check this first.
dont be worried. u need to adjust the vehicle idling . it is normally adjusted by a idling screw at the cng kit, any cng mechanic can do this job. if car is on petrol to race increase kar wa lo
I took to the mechanic and as advised told him to increase the race. It does not vibrate now. Thanks to all of you people for the advice. You people rock.
No Problem ... ...
