if you swap engine & transmission you will be required to reconfigure the 6 mountings 4 for engine & 2 for transmission. Transfer case can be used from your very own vehicle. If only engine is swapped you will be needing a bell housing adapter plate and engine mount relocation / placement.
not to forget complete set of wiring with engine.
