Basic Tips
Beyond using Havoline? with Deposit Shield? for regular changes and top-ups, there's a lot you can do to maximize the life of your car:
1.Rotate your tyres at every 10,000 km or as recommended by the manufacturer.
2.Don't carry unneeded weight in your vehicle. Excess weight puts a heavier load on the engine, causing greater fuel consumption.
3.Accelerate slowly and smoothly. Avoid jackrabbit starts. Get into a higher gear as quickly as possible.
4.Avoid long engine idling. If you have to wait for a long period of time, it is better to turn off the engine and start again later.
5.Avoid engine lag or over-revving. Use a gear position suitable for the type of road you?re traveling.
6.Avoid stop-and-go driving. Stop-and-go driving wastes fuel.
7.Don't rest your foot on the clutch or brake pedal. This causes needless wear, overheating and poor fuel economy.
8.Keep all wheels in proper alignment. Improper alignment not only causes faster tire wear but also puts an extra load on the engine.
9.Keep your vehicle tuned up and in top shape.
10.Getting better mileage is actually simple. Just take it easy while driving. It will also make your vehicle last longer.
11.Take to the shade rather than keep the air conditioner running.
12.It's a good idea to do a safety check before starting out on a trip. A visit to your mechanic can help ensure safe and pleasant driving.
13.Remember to check your car?s oil and water levels regularly, and always double check that the oil cap is securely in place before driving off.
14.If you?re planning a family holiday or a long road trip with friends, it?s always a good idea to do a safety check before heading out. Check your oil, water and brake fluid levels. Ensure your engine has sufficient coolant, and check your tyre pressure.
15.While it?s common practise to check your car?s oil and coolant levels regularly, brake fluid is often overlooked. To keep your car running smoothly and safely, you should change your car?s brake fluid at least once every two years.
