May 2015
1 / 8
May 2015
May 2024
Salam
Mujhay apki raye chaiay hai air cooler laynay may . may 100w tak ka air cooler dhonda raha hon jo ups pay bhi chal jay. wasy hamaray pass 400w wala hai or woh bohat he havey hai local market say lia hai
maynay super asia kay dekhay hain web par acahy lag rahay hain kia woh 100w eletricty use kartay hain yah ziadah use kartay hain?
or aj kal sona hia kay car kay radiator walay air cooler bhi hain kia woh 100w laytay hain?
  • created
    May '15
  • last reply
    May '24
  • 7
    replies
  • 14.5k
    views
  • 6
    users
that would be an irani small size cooler .. bought it new for 12k in 2011 .. works silently and very effective .. hope u can find it in lhr otherwise buy it from quetta if u have any contacts
Picture please.
Mine is in rawalpindi .. here is a pic from net ... thte small beige one with packing material on top of it .. lower stand has wheels
You are right, these coolers are available in Hall-Road-Lahore..
Fan for air-cooler is same Car-Radiator-Fan... consumption around 4-5Amps on 12-Volts
Some ppl are using the Car-Vipers-Pump as a Cooler-Water-Pump... consumption around 1-Amp on 12-Volts (but its not a good one in quality and went out of order in 1 or 2 week or so... Other 12-Volts Water Pumps (around Rs.700/-) also available this year in the same market, but i have no idea about its consumption, my idea is, it will be around 1-2Amps on 12-Volts.
So total consumption of this 12-Volts-Lahorie-Type-Air-Cooler is around 5-7Amps on 12-Volts (i.e. 60-84Watts you may say well under 100Watts), you may use it directly connected with a battery or through a 12-Volts Charger/Adapter or through your UPS.
Although this is a small size Lahorie-Air-Cooler but as works continuously (cause i am using it for 18-20 hours out of 24-hours a day, through battery/ups and no load shading effects on it), its result is quite good.
if u get this thing, make is sure the fan/pump are good quality, cause there are ppl in market selling the repaired/scrap things.
bro what about its performance in karachi climate ??
it i small and can only be placed inside the room .. if u fix in window then the grill or gauze will hinder air ... its air pressure would be like a 1 ton ac ... so recommended for a small room or less people .. plus humidity is a air cooler killer .. when i bought it i was in quetta where summer is not that hot plus i wanted it to work on ups .. just sent it a few days back to pindi or i would have shown it to u in karachi
8 years later
closed May 24, '24
