NOT FOR SALE ANY MORE >>>> DECIDED TO SWAP IT IN MY EKAs the titles i hv b16/b20 engine 4 sale.Specs: B16 head B20 fresh block.B18 type r cams installedafter market cam gears Blox air intake manifoldBlox 68mm throttle body10 mm plug wiresIridium plugsSpoon sports 4-2-1 exuast systemQuaife LSD difrential in b16 y1 gear boxToda racing flywheelToda racing presure plateAct 6 puckRed powder coated tapit coverAn extra high compression b20 block also available. Neat and clean engineProgramed ecu.Evrythng is complete.
Contact 03349169892
B18C5 cams on stock b16 valve retainers and springs ? and is it b20b or b20z ?
pm'd u
best of luck Haroon...ur setup remind me of my B20vtec
thanks salik bhai
@ virus... its b20band the demand includes the high compresion block as well... the compression is above 13:1
Nice man but you're using those cams on stock b16 valvetrain ?
somfing rare..@poster best of luck man:)
yes he is using b16 1st generation head and can hold the type-r cams no problem!best of luck Dactar saib
Thanks asad And immad
Bump
ahh nice setup in which car were u running this setup
Bro it was running in charade gtti
Price is negotiable for serious buyers
still not interested in parting out ?
could you please text (preferred; 0333 987 8877) or PM me the rods, pistons, rod bolts, bearings detail as well as some approximate performance figure that you believe (or dyno tested) you might have made?
@ oformer.Bro the block is jst aquiped vd high compression piston by increase the stock bore to 85mmThanks
bump with price reduced
whats the condition of the setup, has it been compression tested?
^^î heared its in great nick at present.rest poster can tell you better.
