I am using Liqui Moly KFS 12+ coolant in 30% mixing ratio with distilled water. There are two LM coolants in Pakistan:
- KFS 11: https://products.liqui-moly.com/radiator-antifreeze-kfs-11-4.html
- KFS 12+: https://products.liqui-moly.com/radiator-antifreeze-kfs-12-4.html
As per the description, both coolants are safe for cast iron and aluminum engines. KFS 11 is amine, nitrite and phosphate free whereas KFS 12+ is amine, nitrite, phosphate, borate and silicate free. Both coolants are ethylene glycol and do not contain any form of alcohol which complies with the owner's manual guidelines.
EDIT (point added): KFS 11 does not show a Mitsubishi Heavy Industries approval/compliance but KFS 12+ does show. That was another factor in my decision.
Liqui Moly has quite a few exclusive authorized dealers in Karachi, Lahore and Islamabad (don't know about other cities). They keep LM stock only so you can be assured they have authentic products available.
Interesting point to note that the owner's manual is silent on OAT and HOAT coolants. So if LM says that its OAT coolant is safe for cast iron and aluminum engines, and the coolant complies with all other stated parameters in the owner's manual then I believe it is safe to use.
Here are the pages from the owner's manual regarding coolant specs (full scan of which has already been shared in a thread titled Dewan Lancer Manuals).
Pages from Lancer Owner's Manual.pdf (1.3 MB)
