Hello members,
I'm pretty sure I'll be tagged as the 'bad guy' by many after they've read this but seriously it's time someone spread awareness how these Projectors actually perform.
Please Note: I do not intend to target anyone's business directly or indirectly through this brief article, this is plainly for awareness.
So, I've been noticing how the Bi-Xenon Projector Kits are gaining popularity here. Came across a number of sellers on Facebook as well as Pakwheels, seen them lying in popular accessory shops as well, won't name any over here.
These come packaged in a fancy box that displays how these so called HID Projectors have rings that change seven different colors (<--- Ricer Material) and states how these are much better replacements to stock lighting.
The box is similar to this:
Now what the consumers see is a brilliant package, as the seller convinces the customer to buy these projectors, an Accord CL7/CL9 passes by and the customer notices how the Accord uses projectors as well and has such crisp lighting. They will expect the same from these projectors.
Question is, are these projector kits good enough?
Well, these are basically Asian made G3 Projectors which use the H4 bulb. They have an ECE cutoff rather than a DOT spec cutoff which is actually a plus point since most of the cars in our country have the ECE cutoff.
If I had a choice, I'd never buy these projectors. Not because I'm biased but simply because of two reasons:
Price tag of around 15,000 a pair, if I invest a couple thousand more, I can buy quality projectors like the Morimoto Mini, Acura TSX, Bosch AL and do a retrofit myself.
Most of the G3 Projectors available here are actually for Left Hand Drive cars, meaning they have a LHD specific beam pattern so they're pretty much useless for our roads, you're better off with your stock lights.
Continuing below..
EDIT: I strongly suggest all the members to go through the following threads as well:
Misconceptions about HID and Projectors - MominHaq
Honda Civic 7th Gen Retrofit - Sixstring
