Hello All
I need some help please. Recently I bought an Acson air conditioner split 1.5 tonnes.
It was cooling very well. In twenty minutes it would chill my room and also I could not sit in front of it for more than 10 minutes without switching it off as it was too cold.
The ac is only two weeks old and the compressor is 3 years warranty with one year parts and services.
How've bee two days ago the cooking went down slightly and my ac man checked it and said that the joint on the outer unit is loose and that there is a gas leak . His checking meter also only showed thirty pounds whereas last week it was 65 pounds.
However, he taped up the joint and refilled some gas.
My problem is that now my ac gas to be kept on for at least two hours to achieve the same chill that it used to in twenty minutes and it is still not the bone chilling cold. he said he has put American Honeywell gas but I have doubts or is that the original ac gas which came in the Acson ac was something even better than Honeywell?
Or is there some other problem? Please guide me should I show it to the shop or some other ac man? Gas issue or something. Else?
Previousky it it was bone chilling now just average
thank you so much
