hi,
Just going through the shaft seal replacement of my a/c compressor Sanden SD-507 (piston based) as this seems to be the only culprit showing leakage signs(slight oil seepage), though it does not leak anything on a pressure test.
Last time i recharged ac gas 10 days ago but it was wasted (apparently) due to this leakage and my ac mechanic thinks that its a shaft seal problem and its a specialized job done by compressor repair shops at Tariq Road.
Please advice if anyone has gone through the replacement of compressor shaft seal, and where it can be done reliably. Also please mention the approx. cost of the process.
Thanks.
created
Jun '11
last reply
May '16
- 33
replies
- 24.5k
views
- 1
user
- 17
likes
- 5
links
