Congratulations on your new car.
@shobi_mw85
I think (not sure) this car has D16y8 engine, anyways....
Also get the valve clearance (tappets) checked.
Check the condition of the distributor and spark plug wires (cracks, cleanliness, resistance, condition of contacts etc) too. Then get the ignition timing adjusted. No need to get throttle body cleaned.
Get the auto transmission fluid changed with genuine Honda fluid (dont use regular Dex3)
All of these things are regular maintenance and will keep your car running in good condition, and prolong its life.
Since you just bought this car, if you dont know previous history it would be good to get the timing belt changed (and water pump too, since it is in the same place, used pump is cheap. Belt might be expensive depending on where you buy it from and the quality).
Since this is a old car, if coolant was not used there is a good chance that the pump would be almost gone by now. I dont have a photo but when I changed my pump half its blades had corroded away.
If your car overheats you will have to do expensive repairs on your engine.
If timing belt breaks you will loose your engine.
