So what makes my Hardbody different, is the SFA. Unlike the USA and a few other countries, we have no kits available that make this conversion a bolt on.
Searching forums and clubs, I can only find around five other conversions like this in our country.
To bring a bolt in kit from the USA costs more than the Hardbody is worth, and for an unemployed person, totally impossible.
In the USA, the guys all go for the Jeep Dana 35 diff, and then re gear and use adapters to convert the bolt pattern on the wheels to the five bolt of the Dana. Or they just run different wheels front and rear.
As cheap as I do things, this was not going to work for me.
I originally planned a front and rear diff swop to Dana to get around this problem. I would also be assured of perfectly matched ratio front and rear.
But again, to get matching diffs, and then regear to my 4.88 ratio, was just too expensive.
I also found many youtube videos where guys were breaking Dana 35 diffs offroad. The universal in the knuckle seemed to be a bit week, as well as side shafts.
I then looked at Toyota diffs. Some even had the ratio I was needing, but they have a narrow track.
I would need to run 50-75mm spacers to get the front and rear wheels to run the same track width.
Then this came along at an excellent price.
The Patrol/Safari has identical track and wheel base as the Hardbody.
We could not let this one pass as the entire vehicle in running condition, was cheaper than what a Dana diff would have cost.
I purchased with the idea that if it did not help with the project, I could add it to my list of projects. Maybe end up with a descent 4x4, or just sell off the spares and make some money.
First problem I had, was that the Patrol was 1500km away from home. Someone from our 4x4 club checked it out for me and did the purchase and moved it to his farm for me to pick up later.
This person already has about twelve Nissans on his farm, four of them are Patrols, so he was able to give me a lot of information as we went.
The first option was to just do a straight body swop onto the Patrol chassis.
But I wanted my 2,7TD engine and not the L28 of the Patrol.
Patrol chassis is 300mm longer at tge front bumper, and the the gearbox of the TD27 and Patrol transfer case was just not coming together.
There were some other factors we did not even know would be a problem untill much later, like the sump that would have been in the way of the front diff.
But we decided to scrap that idea, because I saw another oppertunity to do something even more unique.
To be continued......
Sent from my GT-I9300 using Tapatalk
