When you think of cars with enough power to push themselves through the air at 250+ MPH machines like the and the SSC Ultimate Aero Twin Turbo(255.83 MPH).But honestly the performance of these Ultra exotic super cars is laughable when seen next to the new Mosler MT900 GTR XX Twin Turbo Land Shark by Intense Automotive Design. Why you ask? Because the latest iteration of Johnny Mosler’s mid-engine super car is limited to 305 MPH, a number more commonly associated with kilometers.
The "Land Shark" weighs in at only 1898 lbs (551 lbs less than the GTR XX) and is powered by a 381 cubic inch engine V8 that delivers no less than 2500 HP! The Land Shark can sprint from 0 to 60 MPH in just 2.5 seconds and hits the 150 MPH mark just 4.2 seconds later, but the ridiculous starts to happen 17.5 seconds after takeoff when the speedometer in this MT900 crosses 250 MPH, and keeps on going.
The Mosler MT900 GTR XX Twin Turbo Land Shark will make its official debut at the 2009 Bonneville Speed Week. I couldn’t think of a more appropriate location on Earth.
2009 Mosler Mt900
Engine Specs:
- 381 Cubic Inches
- 2,500+ Hp 10,000 Rpm Twin Turbocharged Terror
- Multi-Fuel System: Gasoline/Methanol/Hydrogen/Ethanol
- 3.000" Stroke With 4.500" Bore
- 2-Motec M880 Digital Engine Management Systems
- Iad Billet Cnc Billet Aluminum Block
- Iad Ceramic Roller-Bearing Crankshaft And Camshaft Bearings
- Iad/Bryant/Keith Black 4330 Knife Edged, Ultra-Light Roller-Bearing Crankshaft
- Iad Cnc Billet Titanium Connecting Rods
- Iad/Cosworth Ceramic Coated Forged Pistons
- Iad 4340 1.000" Diameter .300" Wall Thickness Piston Pins
- 1/16-Inch Child's & Albert Chromoly Rings
- Iad 4-Valve Billet Cnc Aluminum/Ceramic Cylinder Heads
- Iad Ceramic Combustion Chambers & Exhaust Ports; Beryllium Seats
- Iad Custom Laser Cut Head Gaskets, O-Ringed Cylinder Heads
- Iad Custom O-Ringed Intake Manifold And Cylinder Head Intake Surfaces
- Iad/Jesel Titanium Roller Rockers With Solid Titanium Girdle
- Iad/Jesel 3-Piece .160" Wall Tapered 9/16 "-1/2" Modular Push Rods
- Iad/Crower Pinned 1.000" Diameter Roller Lifters
- Iad Ceramic Coated 2.00" Titanium Intake Valves, 1.75" Inconel® Exhaust Valves
- Jesel Triple Valve Springs, Titanium Retainers, 4340 Locks
- Iad Billet Cnc Titanium/Carbon Valve Covers, Polished
- Iad Titanium Roller Camshaft With Ceramic Roller Cam Bearings
- Iad/Jesel Belt Drive Camshaft To Crank Timing, With Titanium Gears
- Iad Cnc Billet Titanium/Carbon Machined Timing Cover
- Iad Harmonic Dampener With Integral Crank Trigger Pickup
- Iad Billet Titanium/Carbon Dual Electric Water Pumps
- All Titanium Engine Hardware
Induction System:
- Iad Cnc Carbon Fiber/Titanium Inter-Cooled Intake Manifold
- 4-Injectors Per Cylinder (2) 150 Lb., (1) 90lb., And (1) 60lb.
- 2-Weldon 34706 6+ Gpm Mechanical Racing Fuel Pumps
- 2-Aeromotive 16302 Billet Fuel Pump Speed Controllers
- 4-Weldon A2047 Series, High Flow 10+ Gpm Bypass Regulators
- 2-Octane On Demand Systems
- 2-Iad Digitally Controlled Integral Fuel Pressure Regulators, 2500 Cfm
- Russell's Braided Steel Fuel Lines With An Fittings
- 2-88mm Iad/Aerotech Water Cooled Ceramic Ball Bearing Turbo Chargers
- 2-Iad/Motec 65mm Prototype Electronically Controlled Waste Gates
- Iad Titanium Exhaust Headers, Flanges, V-Bands
- Iad Titanium Exhaust System
- Iad Titanium Hi-Flow Catalytic Converters, Mufflers, Mounts, Hardware
Lubrication System:
- Iad Cnc Titanium Dry Sump Oil System Capacity=20 Liters
- Iad/Moroso 5-Stage Dry Sump Oiling System
- Iad/Moroso Titanium Billet Oil Pump Drive
- Russell's Braided Steel Oil Lines With An Fittings
- 2-Iad Custom Hi-Volume Oil Coolers
Ignition/Electronics System:
- Iad/Motec Fuel Injection System
- Iad/Motec M880 Engine Management System (Dual M880 Units)
- Iad/Motec Crank Fired Ignition System
- Motec On-Steering-Wheel Mounted Horsepower Management System
- Iad/Motec Power Control System, Variable From 800 To 2,500+ Horsepower
- Motec On-Steering-Wheel Digital Brake Bias Control
- Motec On-Steering-Wheel Active Suspension Control
- Motec On -Steering-Wheel 12-Stage Digital Fuel Injection Control
- Iad/Motec Carbon Fiber Digital Steering Wheel With Integral Digital Controls
- Iad Prototype 8-Speed Paddle Shifters, With Quick-Release
- Motec Pit-Lane Speed Control Button
- Custom Alpine 7.1 Dolby Digital A/V/Dvd/Motec Ems Display
- Lowrance Gps With Front, Rear, Side, 360 Degree Skytm Radar Tracking System
- In-Car Pctm Mobile Intel Core 2 Duo 2.33 Ghz
- 3.5g Mobile Internet 7.2 Mbps
Transmission System:
- Iad Prototype Titanium/Carbon Fiber All-Wheel-Drive System
- Traction Control By Motec
- Iad Cnc Billet Titanium 8-Speed Trans-Axle
- Quick-Change Gear-Box, 30 Sets Of Track Gears
- Weldon K9200-A High Temp Trans & Awd Oil Pump
- Iad Transmission And Front Differential Coolers
Suspension/Braking System:
- All Titanium Suspension Components
- Penske 3-Way Adjustable Racing Shocks
- Fully Adjustable Front And Rear And Sway Bars
- Cnc Machined Solid Delrintm Suspension Bushings
- Carbon Fiber/Ceramic 400mm Diameter Brake Rotors
- 8-Piston, Liquid Cooled, Cnc Billet Calipers
Aerodynamics:
- Front Splitter For Maximum Down-Force
- Front Left And Right Dual Dive Planes
- Left And Right Side Pod Air Intakes And Outlets For Optimal Cooling
- Roof Canopy Air-Intake With Scoop
- Mid Upper Body Section Left And Right Air Intakes
- Flat Belly Pan With Full Length Air Ducting Channel For Maximum Down Force
- Rear Deck Lid Side Vents
- Rear Fully Adjustable Carbon Fiber Rear Wing
- Wheels:
- Dymag Carbon Fiber, Magnesium Center, Titanium Lug Nuts
- Front 11.5" X 19"
- Rear 14" X 20"
Tires:
- Michelin Pilot Sport 2
- Front 285/35r19 Ps2
- Rear 345/30r20 Ps2
Cockpit:
- All Interior Surfaces Are Polished, Clear Coated, Carbon Fiber
- Custom Prototype Design Carbon Fiber Seats
- Schroth Titanium 6-Point Seat Belts
- Dual Carbon Fiber Fuel Cells For Fuel/Methanol
- Registered As A "Hybrid" Vehicle Due To The Multi-Fuel Engine....
- I Will Get To Drive In The Diamond Lane..... Ha! Ha! Ha!
- Fuel Capacity, Gasoline=100 Litres
- Fuel Capacity, Methanol= 40 Litres
- All Vehicle Components (Except A Very Few Internal Engine Parts) Are Carbon Fiber, Kevlar, And Titanium
...... No Other Materials Used .......
- The Trentek Chassis Is The World's Stiffest, Lightest And Most Cost Efficient Car Chassis. Made Of Composite Carbon Fiber/Honeycomb Kevlar, The Trentek Chassis For The Mt900 Weighs In Under 90lbs, (Less Engine, Trans, Wiring, Suspension, Etc.) And Could Be Put Together, By Hand, In Approximately 20 Minutes, Eliminating The Need For An Expensive Assembly Line. This Chassis Is Offered Exclusively Through Trenne Technologies, Inc. And Teklam Corporation. Vehicle Weighs 777 Kilos (1,709 Lbs.), Without Fuel
- Actual Top Speed=305 Mph+
- Cfd/Fea Catia V5r19, Theoretical Physical Top Speed=375 Mph+
- Cfd/Wind Tunnel With Iad Aerodynamic Modifications
- Computational Fluid Dynamics Verified Aerodynamically Sound At Over 400 Mph (After Extensive Iad Aerodynamic Modification)
- (Cfd/Fea Catia V5r19 Verified With Iad Aerodynamic Modifications-Aerodynamically Limiting Vehicle To 305 Mph, With Rear Wing Attached)
- Top Speed=375 Mph+ With 118 Octane Racing Fuel, With Iad Aerodynamic Modifications
- Limited To 305 Mph, With Rear Wing Attached, Gasoline/Methanol Fuel Mix
- 0-60 Mph=2.5 Seconds
- 0-150 Mph=6.7 Seconds
- 0-250 Mph=17.5 Seconds
- 1/4 Mile=9.0 Seconds
- 1/4 Mile Speed=178 Mph
- Zero To 150 Mph And Back To Zero=8.7
- Braking: 250 Mph To Zero In 8.5 Seconds
SOURCE : CLICK ME
:D
