2012 Chevrolet Camaro ZL1
---- Specifications ----
Engine 6.2 liter V8
Aspiration supercharged
Torque 550 lb-ft @ 3800 rpm
HP 550 hp @ 6100 rpm
ZL1: Chevrolet Camaro Enters The Realm Of Advanced Performance Technology
• LSA 6.2L supercharged engine will produce an estimated 550 horsepower (410 kW) and is matched with a six-speed
manual transmission with a dual-disc clutch system
• Packed with performance technologies, highlighted by Magnetic Ride Control, and advanced materials – including a vented
carbon fiber hood insert. Extensive aerodynamic development designed for high-performance driving
• Development ongoing, targeting launch at the beginning of 2012
CHICAGO – The 2012 Chevrolet Camaro ZL1 debuted today at the Chicago Auto Show. It is the highest-performing Camaro and
the most technically advanced car ever developed in its class. The new ZL1 continues the momentum of Camaro, propelling it
into an entirely new realm of leading-edge performance technology. It is planned to launch at the beginning of 2012.
Motivated by a supercharged V-8 engine producing an estimated 550 horsepower (410 kW), the Camaro ZL1 will be the fastest
Camaro ever offered by Chevrolet. And more than just power, the ZL1 features technologically advanced and highly developed
chassis and suspension systems that help it deliver balanced, track-ready handling and braking power to complement its high
engine output. Rigorous development of the ZL1 is ongoing, and official estimates of the car’s capabilities will be released later
in 2011, as testing nears completion.
“Camaro ZL1 is about high-tech performance and design, and is a type of car no one has ever brought to this segment
previously,” said Rick Scheidt, vice president of Chevrolet marketing. “It’s the most technically advanced Camaro ever, so we’ve
chosen a name from the most elite and exclusive Camaro in history.”
The ZL1 name is derived from the all-aluminum racing engine of the same name, which was developed in the late 1960s and
installed into a handful of regular-production 1969 Camaros. Only 69 were built with the engine, but they’ve achieved mythical
status among enthusiasts, as they represented the pinnacle in Camaro performance – until now. The 2012 ZL1 model is
designed to be a major leap forward for the Camaro, bringing a new level of performance capability to the segment.
The central goal of the car’s development was creating something new – a Camaro intended to reach optimal lap times on top
road-racing circuits and excellent driving dynamics on the street. To achieve that goal, engineers evolved many of the existing
Camaro’s systems, as well as incorporated new technologies such as electric power steering and Magnetic Ride Control, the
world’s fastest-reacting suspension system.
Camaro ZL1’s design communicates and supports its performance mission. Rather than using decorative elements, ZL1 is
visually differentiated from other current Camaro models with elements vital to the car’s elevated capabilities.
“Everything about the ZL1’s design is directly related to its technology and serious performance, especially aerodynamics,” said
Ed Welburn, vice president, Global Design. “Our designers’ goal was to execute that function-oriented design with beautifully
sculpted forms, creating an imposing, powerful persona. Function becomes the aesthetic. The intent is a car that delivers on
the attitude it projects.”
Major elements of the ZL1’s design are a new front fascia and hood with air extractors, designed in tandem to create
aerodynamic downforce to aid handling. The car’s hood includes a signature center section constructed of carbon fiber and
rendered in satin black finish. New rocker panels, wide tires, 20-inch wheels and exhaust tips portray the car’s handling and
power. The ZL1 badge appears on the grille, hood and the brake calipers, all key areas portraying the technology within.
Tech overview
Supporting the dynamic track and street performance of the ZL1 is the LSA 6.2L supercharged engine, which will produce an
estimated 550 horsepower (410kW) and 550 lb.-ft. of torque (677 Nm), with specific features for the Camaro. Built on GM’s
legendary all-aluminum, small-block V-8 architecture, the LSA features an intercooled supercharger system, premium
heat-resistant aluminum-alloy cylinder heads and other details designed to ensure its exceptional performance is delivered with
smoothness and refinement. Components and design elements that contribute to the LSA’s performance include:
• Balanced, lightweight reciprocating assembly
• High-strength hypereutectic pistons
• Sixth-generation Eaton supercharger with four-lobe rotors
• Piston oil squirters.
Because the Camaro ZL1 uses electric power steering, the engine does not incorporate a conventional hydraulic power steering
pump on its accessory drive system. This enhances performance, because no engine power is used to turn a steering pump
pulley.
Camaro ZL1 is a complete high-performance car, not just a Camaro with more power. Key technical highlights include:
Transmission – The high-performance Tremec TR-6060 six-speed manual is matched with the LSA engine. It is the “MG9”
version of the transmission, with a higher torque capacity. It is used with a dual-mass flywheel and twin-disc clutch for easy
operation and shift smoothness. A new, shorter-throw shifter actuates the gear changes.
Exhaust – ZL1 is equipped with a dual-mode exhaust system, which alters the sound level and character in response to engine
rpm. First used on the legendary Corvette, and specifically tuned for Camaro ZL1, the dual-mode exhaust will give the car a
signature sound.
Drivetrain – It is revised with a stronger driveshaft and rear axle system, featuring a larger and stronger cast iron differential
housing, stronger axles and heavy-duty limited-slip differential. This patent-pending system is designed to ensure that ZL1’s
tremendous power is delivered smoothly to the ground.
Suspension – The suspension features completely revised tuning and the inclusion of segment-exclusive Magnetic Ride Control.
ZL1’s Magnetic Ride system will include driver selectable modes (Tour and Sport) tailored for the preferred style of driving. It
uses advanced magneto-rheological science to produce shock damping with the highest level of precision, enabling body control
optimized for excellent performance in everyday driving as well as track situations. This technology appears on only a small
roster of some of the world’s finest performance cars. Other chassis elements are redesigned to support the car’s
high-performance limits. Rear stabilizer bars have drop links repositioned outboard of the control arms. This makes the bars
more effective in controlling body roll in turns, with crisp response to driver commands.
Brakes and Steering – Camaro ZL1 features an advanced track-capable braking system, developed in conjunction with experts
from Brembo. The large 14.6-inch (370 mm) two-piece front rotors have six-piston calipers; the 14.4-inch (365 mm) rear
rotors have four-piston calipers. ZL1 marks the entry of a new electric power steering system to Camaro. It is being developed
to ensure precise control and feedback to the driver, with greater variability of effort for high-performance driving.
Exterior – ZL1’s signature from the front is the redesigned fascia and aluminum hood with a raised, carbon fiber insert. The
fascia includes a front splitter and new vertical fog lamps. The fog lamp area includes air intakes designed for brake cooling.
The hood features front-mounted air extractors that direct air precisely over the car. Visually, this center section, in satin black
carbon fiber, communicates the car’s high-performance intent as a visual contrast to the car’s exterior color. Functionally, the
air extractor is a key in connecting airflow closely to the bodywork, creating aerodynamic downforce. The carbon fiber center
section reduces the mass of the hood. High-intensity discharge (HID) headlamps and fog lamps are standard. The rear of the
car includes a diffuser and spoiler, also functional elements that enhance the car’s aerodynamics.
Wheels and Tires – New-design, 20-inch forged aluminum wheels, which are lighter than the 20-inch wheels used on the
Camaro SS, are used with new Goodyear Supercar F2 ties developed specifically for the ZL1.
Interior – ZL1 is tailored for high-performance driving. The front seats feature microfiber suede inserts. Other enhancements
include a redesigned steering wheel, alloy pedals, Head-Up Display with unique performance readouts and the “four-pack”
auxiliary gauge system featuring a boost readout.
Production details
All of the Camaro exterior colors will be offered with the ZL1, but black is the only interior color. The unique exterior features
are complemented with a black center section on the hood. Inside, the Camaro ZL1 has heated leather seats with microfiber
inserts and ZL1 logos embroidered on the front headrests. Microfiber suede is repeated as an accent on the instrument panel,
adding a richer look to the interior. The ZL1 will include the same content as the current 2SS package and include the following
new or unique features:
• Six-way power driver and passenger seats
• Unique instrument panel and door panel inserts; and ZL1-logo sill plates
• Steering wheel audio controls with Bluetooth capability
• Wireless PDIM and USB-port
• Boston Acoustics premium audio system
• Rear parking assist
• Rear camera system (displayed in the inside rearview mirror).
Engineers have already driven Camaro ZL1 prototypes extensively at demanding road courses in the U.S. and Germany, with
final testing being completed through the balance of 2011.
