2006 Gemballa Mirage Evolution - Carrera GT
As it turns out, the concept photoshops of Gemballa's Carrera GT coupe didn't lie, thier proposal to make one of the most outrageous supercars is now a reality on pakwheels and we now have pictures of their new model in the wind tunnel undergoing tests.
Gemballa USA is seriously representing that they are going to modify a Carrera GT in much the same way they push out the current 911 to make over 750 bhp. That is, attach twin turbochargers and make a 1000 bhp monster.
However, Gemballa's ambitions don't end there. This hypothetical makeover also includes a gullwing doors and a new carbon fiber roof, tested in the wind tunnel for 250 mph crusing.
Do I believe this? Oh yeah! Unfortunately, Gemballa told the Dupont Registry it would take 1.5 million euros to complete the upgrade so we are guessing that this feature example will be the only one.
Spec
Price: $2 000 000 USD
Engine: Modified V10 w/Low Compression Pistons
Position: Mid Longitudinal
Aspiration: Twin Turbochargers
Valvetrain: DOHC 4 Valves per Cyl
Fuel feed: Sequential Multi-Point Fuel Injection
Displacement: 5733 cc / 349.8 cu in
Bore: 98 mm / 3.86 in
Stroke: 76 mm / 2.99 in
Power: 745.7 kw / 1000 bhp
Hp per litre: 174.43 bhp per litre
Bhp/weight: 724.64 bhp per weight
Torque: 1201.25 nm / 886 ft lbs
Drive wheels: RWD w/ASR 5.7, LSD
Body / frame: Carbon Fibre Body over Carbon Fiber Reinforced Plasitc Frame
Front brakes: Internally Vented & Cross Drilled Ceramic Composite Discs w/6-Piston Calipers, ABS
F brake size: 400 mm / 15.7 in
Rear brakes: Internally Vented & Cross Drilled Ceramic Composite Discs w/6-Piston Calipers, ABS
R brake size: 400 mm / 15.7 in
Front wheels: F 48.3 x 25.4 cm / 19 x 10 in
Rear wheels: R 50.8 x 33.0 cm / 20 x 13 in
Front tire size: 275/30-19
Rear tire size: 345/25-20
Steering: Rack & Pinion w/Power Steering
F suspension: Double Wishbones w/Inboard Springs & Dampers
R suspension: Double Wishbones w/Inboard Springs & Dampers
Weight: 1380 kg / 3042 lbs
Transmission: 6-Speed Race-Sourced Transaxle
Source: Gemballa USA
