can anybody guide me the exact location of civic 2005 fuel filter so that i can replace it i am having a hard time locating it lol...the car has dont 3 lacs on its odo and i havnt replaced the fuel pump and the filter i was successful in chagning the pump while un able to locate it the filter in the fuel tank as my corolla has it connected with the fuel pump in the tank thanks guys
3 lacs on its own engine ? did you check rear left wheel location, if not in fuel tank it should be around thr
I think it is the part of fuel pump assembly.
yes for this model, its part of pump assembly.
It is with the fuel pump assembly I should appreciate you as you have a very maintained car My civic 2005 vti prosmatec also has 300,000kms on the odo with genuine engine and still 10W30 oil it it still doesn't burns
It is close to rear left tyre. You need to go under the car from left side, it is between the fuel line. changed mine twice. It looks like this.
As far as i know, exi has this filter. I and many others could not find inline filter in their cars. Some cars came with this while some only have filter that is part of pump assembly. Its called strainer
What works you have done so far on your car to keep it running for 300k odo?
Where do you get the work done? (mechanic contact etc?)
Any suspension work done so far?
Where do you source parts and do you use genuine or kabli or what
Maybe, as I have Exi and fuel filter is there. But again in Exi some cars don't have it. I think it came in cars produced in specific years.
I maintained the car from the company Just regular maintenance Yes I changed the shocks from company and agly hissa ka kaam b company sa krwayaNever used kabli... Everything that company sales has better life than the things you get from other shops.. I changed brake oil, power steering oil and disks recently..
well getting all the work done from honda is quite expensive. Parts and labour both are very expensive and not easy to afford for everyone for a 12 year old car
Bro it's expensive but it worth it.. One of my friend have the same car and changed the socks from other than Honda and got on half price than me and those shocks also has packing of same like mine But while comparing both Visible difference was there..And I'm sure If I don't get it company maintained then the car might have lived its age.... I'm maintaining it since 2005 from company and I'm satisfied.. Their is nothing more than regular one. Just change oil, wheel alignment balancing trans oil and after 1 lakh timing Belt just.. And if suspension needs some work then that bss..
