The Dream Comes True HONDA CIVIC Specifications.
Type EXi VTi
ENGINE
Type Water-cooled 4-stroke SOHC
16-valve in-line 4-cylinder
Transversely Mounted
Fuel Supply System (mm) PGM - FI (Programmed Fuel Injection) PGM - FI + VTEC - III
Bore / Stroke (mm) 75.0 X 84.5 75.0 X 90.0
Displacement (cubic cm) 1,493 1,590
Maximum horsepower
(KW (PS) / RPM) 81 (110) / 5,800 96 (130) / 6,600
Maximum torque
(N.M (KGM) / RPM) 135 (13.8) / 4,500 146 (14.9) / 5,000
TRANSMISSION
Manual Synchromesh five forward speed, one reverse
Prosmatec 4 - speed fully automatic (Progressive Shift Management Technology)
STEERING SYSTEM
Gear Type Rack & pinion, Power assisted
DIMENSIONS
Overall length (mm) 4455
Overall width (mm) 1720
Overall height (mm) 1455
Wheel base (mm) 2620
Tread (Front / Rear) (mm) 1470 / 1470
Ground clearance (mm) 170
SUSPENSION SYSTEM
Front New McPherson Strut front suspension
Rear New rear double wishbone suspension
BRAKING SYSTEM
Type 4- wheel disc brakes 4 - wheel disc ABS
(Anti-Lock Braking System)
Electronic Brake force Distribution (EBD) X O
TIRE / WHEELS
Tire Size 185 / 65 R 14 (86H) 185 / 65 R 15 (88H)
Wheel Size 14 X 5 JJ 15 X 6 JJ
