1992 Honda Civic Cx Harness
Engine 2.0L naturally-aspirated B18C1; engine build by RS Machines, sleeved and bored to 84.5mm, 89mm stroke, 11.9:1 pistions; head port and polish by Alaniz Racing; Skunk2 PRO2 cams, PRO series intake manifold, valvesprings, retainers, header, radiator cap; BDL cam gears, timing belt, 72mm throttle-body, fuel rail, fuel pressure regulator, misc clamps; CTR crank pulley; Innovative engine mounts; Go-Autoworks 3'' intake, oil catch can; walbro 255lph fuel pump; RC Engineering 440cc injectors; Chasebays custom fuel line and grounding kit; Blox fuel pressure gauge; custom Street Image 3''' v-band exhaust w/Burns Stainless muffler, Street Image custom fan shroud; NGK spark plugs; MSD external coil; BAKER battery; Koyo aluminum radiator shaved and polished by Mag Master; Rywire Mil.Spec engine harness; custom Plan B billet valve cover w/removable timing cover; Vibrant Performance Scavenger oil cap; Password:JDM dress up bolts and hood dampers; powdercoated engine block and transmission
1992 Honda Civic Cx Ramsin Engineering Lca
Drivetrain GSR Y80 transmission built by Street Image; ITR LSD; ATS 4.9 final drive; Clutch Specialties 6-puck clutch and custom flywheel
Engine Management Hondata S300 tuned by Elton @ Raceline; Blox water temp, oil pressure and fuel pressure gauges; A'PEXi VAFC2
Footwork & Chassis Function Form front coilovers w/800lb springs; Eibach drag rear coilovers w/1000lb springs; Skunk2 PRO front camber kit; Blox rear camber kit, 22mm sway bar w/endlinks; Mugen front strut bar; custom ASC 8-point rollcage and rear strut bar; Ramsin engineering rear LCA and subframe brace w/lower tie bar; Energy Suspension bushings; powdercoated sub frame, knuckles, UCAs, LCAs, trailing arms and steering racky
1992 Honda Civic Cx Mike Ghadimi
Brakes Custom powdercoated Wilwood front calipers and rotors; Chasebays custom brake lines
Wheels & Tires custom powdercoated 16X7'' Enkei PF01 wheels w/215/45R16 Falken Azenis RT-615 tires; ARP extended studs; Blox lug nuts; 20mm front spacers
Exterior BMW Z4 Urban Green paint originally by MOB Works w/newly repainted sections by LR Auto Body; Charge Speed +20mm front fenders and lip, Go-Autoworks rear diffuser; J's Racing rear wing and air duct; JDM EG6 headlights; Vision smoked amber corners; Password:JDM smoked side markers; Spoon style mirrors; Circuit Hero rear tow hook; decals by Jprint
Interior STÄTUS Kevlar seats; Wedge Engineering seat brackets; MOMO steering hub and steering wheel; NRG quick-release; Judgement shift knob; Mugen pedals; JDM EG6 gauge cluster; optional audio console and arm rest; custom door panels; custom gauge pod by Street Image
1992 Honda Civic Cx Custom Engine Cover
Audio Gryphon head unit; Sony Xplode speakers
