Engine: DMS Performance full engine build; CP Pistons 9:1 compression ratio; Carrillo rods; LA Sleeve sleeves; main crank journal align bored; Cometic head gaskets; ARP head studs & main studs; Science of Speed billet main cap set; VVIS system delete; new lost motion assemblies; Time sert block; Supertech exhaust valves, 36mm intake valves, & valve springs/retainers/bases; Foundry 3 billet motor mounts; CRF Titanium timing belt shield; ATI super damper crank pulley; Science of Speed EGR block plate kit; O-ring cylinder heads; timing belt tensioner; custom breather tank for crankcase; Science of Speed oil pan baffle with new oil pan & oil pump upgrade; Foundry 3 custom titanium charge pipe with pie cuts & billet alternator bracket with new alternator; Lovefab LF600 stage 2 turbo kit; air-to-water intercooler; Precision 67/66 billet ball bearing turbo with .81 coated exhaust housing; Walbro 450 fuel pump; stainless fuel feed upgrade with high-flow filter; ID 1000 injectors; TiAL Q blow-off valve & 44mm wastegate; Lovefab twin chamber coolant tank; SDuff composites full carbon intake manifold cover & fuse box cover; ChasingJs titanium intake manifold plate & throttle body cover; Mugen oil cap; RFY coil pack rain guard; AEM Series 2 flex-fuel tune; Lovefab stainless steel coated headers; DMS Performance custom titanium 3-in. straight pipe center exit exhaust coming off the turbo; Foundry 3 custom titanium 3-in. dual tips; AEM EMS V2, flex fuel sensor, in-line wideband UEGO AFR controller, electric boost controller, fuel pressure regulator, & F/IC piggyback controller; GaugeArt CAN bus video gauge adapter with LCD display; FRONT BAY: SDuff full carbon fiber radiator cooling panel & radiator brackets; KOYO aluminum radiator
Drivetrain: Clutch Masters 850 series twin disc race/street clutch with aluminum flywheel; Insane Shafts 1000hp axles
Footwork & Chassis JRZ RS 2 coilovers complete with springs and bearing top mount kit; ChasingJs 4-pt. titanium rear chassis brace
Brakes: Upgraded rotors; powder-coated calipers
Wheels & Tires: VIP Modular VX410 wheels - 18x9.5" (front), 19x12" (rear); Hankook Ventus V12 tires - 245/35 18 (front), 325/30 19 (rear)
Exterior: Sorcery V1 widebody kit (front bumper, front fenders, side skirts, rear fenders, rear bumper); OEM 2002-and-up front end conversion; NSX-R style carbon fiber hood & rear wing; carbon-fiber front splitter, canards, & side splitters; MRacing carbon fiber mirrors; Avery Black Chrome vinyl wrap by Hollywood Customs; custom carbon-fiber diffuser; NSX-R door handles; Plastics 4 Performance Lexan margard rear hatch with functional I's Impact carbon fiber scoop; SDuff composites full carbon rear hatch garnish; OEM NA2 tail lights with NSX-R center garnish; NA2 R front Honda emblem
Interior: SDuff composites full carbon kevlar shell bucket seats with NSX-R style red alcantara and padding; Taitec seat brackets and sliders; custom carbon-fiber nav pod; Science of Speed nav pod bracket & LCD screen for gaugeart; SDuff full carbon-fiber double-din center console, arm rest, window switch bezels, headliner with sun visor delete, A pillars, & B pillars; K's Racing carbon-fiber gauge cluster trim; SDuff custom carbon-fiber/alcantara OMP SuperQuadro steering wheel; NSX-R horn; upgraded white speedometer; Zanardi floor mats; SDuff full carbon-fiber rear long bulkhead, side sail panels, rear rectangle panels, center speaker, side bolster caps, rear view mirror cover, & lower cowl covers; ChasingJs titanium steering wheel bolts & 90mm weighted shift knob
