1990 Nissan 240SX S13 - Licensed To Ill
Fast Facts
1990 Nissan 240SX
Owner tommy cho
Hometown villa park, Il
Daily Grind owner of ill garage
Under The Hood 2.0L turbocharged SR20DET (S14); Borg Warner S362 Turbo from Bullseye Turbo; lightened under drive pulleys; iLL Garage custom intercooler; ARC oil pan; Earls AN fittings and stainless lines; Avid solid mounts; TiAL wastegate; HKS SSQ blow-off valve; Vibrant air filter; Deutsche Werks 810cc injectors; Koyo radiator; Grex oil filter relocation kit; Alchemy turbo manifold; ISIS turbo exhaust; VS Racing 12" slim line fan (X2)
Drivetrain competition clutch stage 4 clutch kit, ultra lightened flywheel; driveshaft shop solid aluminum driveshaft; nismo 1.5 way lsd
Brains nistune engine management
Stiff Stuff cusco zero-2r coilovers; modified s&w custom roll cage; yamato garage ruca, toe rods, traction rods, tension rods; touge factory steering bushings
Stoppers Z32 front and rear brakes; ichiba extended studs; stainless steel lines
Rollers 18x10 -0 (front) 18x13-36 (rear) custom purple work meister s1; muteki sr48 neo chrome extended lugs
Outside PPG charcoal gray paint; version select s15 front bumper, s13 to s15 conversion fenders; jdm s15 headlights; jdm kouki taillights; origin stream side skirts, stream rear bumper, 50mm over fenders (modified to 70mm); aero catch hood latches; seibon dv s15 carbon-fiber hood
Inside simpson 4pt harness; bride vios iii low max bucket seat; buddy club seat rails; b&m short shifter; proper ***** shift knob; 350mm personal grinta steering wheel; nrg 2.5 quick-release and short hub; faux-suede covered dash; 5 panel rear View mirror
Props big ups to ill garage crew for spending late nights till mornings getting the car together, bullseye turbo, melissa @ competition clutch, aj @ last chance coatings, andy @ nistune, nos energy drinks keeping us alive, and all of midwest coast keeping the scene live!
