MG HS only 32k driven has been giving DCT issues. Sometimes it won't engage. No MG 3S shop has answer for it. Engine will be ON but as I shift the gear, it will simply not move and give Engine Fault error. Upon several restarts and changing modes and trying everything including using sports mode for manual shift, sometimes it will work, other times it won't. Then if the car is left for a few hours the error and issue, will go away for several weeks as it never happened. It will come back anytime and anywhere. Recently, it happened while the car was moving, same thing, engine is reving but the transmission won't work, upon several restarts, it will work and then after a few hours the error would go away.
The MG 3S had used their computer checks 3 times already and have no error log detected. I have made a small video of this happening as well. Has anyone here experienced the same? and how did you fix it? Please HELP.
