What’s the problem with the AC and have you tried closing the hood with a bit of force
Yes i tried that , the ac and fan stopped working since this warning it's something else
The hood problem is just a loose sensor that needs to be tightened , not sure why your AC isnt working
I'll get it checked from mg
The sensor per se
Is actually in the lock system, and the fans also not working means that there is a grounding fault to the front clip of the car.
Any recent “accessory” work done to the car like HID or horns?
got it checked , a mice bit off the ac wires and bonet sensor
Yes that mice problem seems to be a big thing, one bit off my key sensor coil. I heard from the MG mechanic some mice have bitten off complete wirings
are mice specially interested in MG car wiring? - the insulation probably is made from soy or other similar material (Honda in USA suffer from this problem, so they literally have a spicy tape to prevent mice eating the wiring)
Is this issue specific to MG in Pakistan? I think new Toyotas and Hondas use the same type of wiring too.
in USA this is specific to Honda only, they have soy based wiring insulation which is tasty for rats and mice. Some other manufacturers also specced it but dropped that idea and replaced all those wiring looms under warranty.
What is the fuel consumption of mg hs…..recently I bought hs the average is 8.5 on Highway….
@Xulfiqar your knowledge make me jealous . I m not sure but per my impression you are not in Pakistan.Man you must have workshop chain in Pakistan even if you are there
He lives in USA
