suddenly i got 3 light on in same time traction control +abs+emergency brake any solution and cause ?
hook it up with a scanner to check whats causing itif in rwp/isb you can go to burrak autos
Could be a bad abs sensor, or abs unit. Yes, scanner is your only option here. It will tell you what’s faulty.
Rana Bro. Check your brake fluid first. One of my friends got this error and i fixed it for him by filling up the brake fluid. Also have your Brake Pads checked they might be worn out. Let me know how it goes.
OR
Its a bad wheel bearing.
thanx bro main nay check karwaya no issue in any type just mar cars brake switch relay was wet jub bhe wash karwao ya prob ajata ha 2 nd day sub normal ho jta ha
im having teh same issue since i bought aqua 2 weeks back all these 3 warning signs are on but car is running just perfect.. dont know what to do.
Aoa all..All three check lights are on since yesterday...Scanner is indicating it as actuator of motor as told to me by auto mechanic...wht would be probable cause??Would it require to change complete ABS ??
sir your location please @irfan4984122
Brother Actuator is the ABS motor and there is no mai ka lal in pakistan who can repair it even after repair it's going to be problematic for you to go with the best ABS available in PK. it will be a stupid move to go for a Sasta or jugaru ABS it's going to waste your money your car and your time.
