I got henna (mehandi) stains on my car, I tried everything but its not going. If anyone knows the solution please let me know.
@saad310799
Try to perform rubbing polish otherwise hinna is based on chemical almost and its penetrate inside from surface . You may need water based micro sand paper until color fade up
Try rubbing with a little petrol else you have to go with sanding and then compound
dont waste your time with rubbing compoundswe tried and result was zerogo to painter and see if wet raigmar and compound can help
else it will keep fading out with time
Compound alone will do nothing for it we have to sand and then compound is necessary
Henna on exterior or interior (seats)???
@pwuser161869219922 Mehendi k nishan khtm ho gaye thy apk? Kesy huy? Kon sa tarika kam aya? Help me too if something got work.
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
