This chart is for units with FO type expansion device with ventilator open to evaporator
Meaning fresh air going into cabin and a rather large ac system.
Dont use it as gospel, you have a small system with T shaped txv
fill unit by weight and make sure your fan clutch is working as it should., also make sure the expansion valve is correct type and correct installed too.
