My GS 150 SE model 2022 approx 13k driven gets very Heatup when drive for around consecutive 10km. Even my feet can feel the heat at around 1 ft distance. And sometimes I feel my gears are wearing out and I feel vibration in handle as well. Note I am using Suzukis recommend engine oil i.e 10 40. And just recently changed the oil and filter both. And also even in current summer season my self start doesn't work at first I have to attempt multiple times to get my bike started. Can anybody suggest what is the potential problem?
@vickytulla @r1 it is about the motorbike
what is the spark plug code you are using? when was the last tappet adjustment done? (in terms of kms)
you may be needing an oil cooler. check youtube for GS150 engine oil coolers.
Most probably your bike is running on lean mixture. Which oil is your bike on right now? Also make sure the brakes are not very tight at front and rear.
@Hassan1991 Switch post to concerned relevant bike section i.e. Suzuki Bikes under Bike Forums
According to my knowledge its engine oil problem...I have already faced this problem two three times in my GS150...which brand engine oil you are using???
almost all borothers responded to the point and correct... there are two main reasons...
Bad or wrong grade oil or may be fake oil... or a too lean carburator.
Last time used Suzuki 1040, before not sure which brand was in used
Don,t use suzuki genuine oil its farigh use any other brand
Can you suggest anyone? Brand with grade?
