CD 70 stopped while running, mechanic cleaned carburettor, now it does missing at low speed when I start runnin bike in first and second gear in morning, it runs normally through the day and no missing
check your slow jet.
Most probably he messed up the fuel settings. Do check the spark plug if its light brown then your bike is running on lean mixture and require minor adjustment.
Is cd 2021 original slow jet available on shops. Or current slow jet can be cleaned/ repaired? Please advice me.Thanks
go to any spare part shop , they'll give you , make sure you install the same number one.
There is no need to replace the genuine jet. Just clean with petrol if clogged.
The problem was solved by myself. My carburettor needle was on top groove. I put it in second groove, bike missing was reduced. Then I put it in third groove, no missing now. I want to know what was exactly the problem. What change came in carburettor so missing was gone?
