Have you self imported? can you arrange for 2007 as my car also need ABS unit
new battery price ?
prius 2012 available in pearl white color
Aoa. I own a 2011 Prius with 115k on ODO. Recently I am facing a strange issue that whenever I go for a highway drive and car exceeds 100kph with AC Coolant overheat light comes On and start blinking. When I release the pedal and car spools down the light goes off. This keeps on happening on the highway. In City I drove for a couple of days but that light didn't show up. I checked the coolant level but it was ok. So I cautiously changes the coolant but still the light comes On above 100kph. Any suggestions that what might be the fault?
any of you facing rattling / squeaking sound coming from dashboard/door panels and center console in 3rd gen prius
I think its time to change ABS assembly.
But before replacing ABS unit go for brake flush, if you heard noise again after brake flush time to spend money on ABS unit (Appx Rs.50,000/- Rs. 60,000/-)
Check the water body pump, as known in local language.
Water pump body was leaking 4 months back so I replaced it then.....As far as the solution to the problem is concerned a mechanic advised to check its radiator (Get it washed or replaced) so keeping fingers crossed I got the radiator washed and guess what the whole radiator was choked with carbon deposits.After washing I again changed the coolant and till now I haven't seen overheat light and hoping to not see it again.
Wow. Congratulations.
one person i know faced the same problem...he opened his door panel and found loose clips...u might check that
i am in search of one....:()
This is normal for Prius. Start with dash board corners, take small pieces of Black Jumboloon and push then in gaps along the body. Similarly the 2 dash board doors need packing when closed
Oil recommendations for 200k driven and do we also need to replace the coolant?
Dear Ahmed,
It has driven 200K in Pak or elsewhere? Bcz if its in Japan, then you may continue with 0-20 which is recommended for Prius. But if it's in Pakistan, then better to follow which you are already using.
HiI got tuning done of my prius gen 2Throttle body cleaningInjectors etcSpark plugs also changed
After that my car is giving less average, it used to give me 20+ the way i drive but now it stays on 14-15 after a lot of hyper-milling. Battery health is 100% got it checked. I think the spark plugs that he replaced are not ideal for this car. I dont have the old spark plugs. Can someone guide what spark plugs are recommended in prius gen 2 2007 g toruing?? Thanks
probably iridium are recommended as for other JDM'sdid he re-calibrate after throttle cleaning?as that is required, else car will learn on its own after a tank or so and your average should return back to normal considering all other things are fine.
Thanks faridI got SK16R11Read from the manualAverage is back to normalMechenic refused to change the plugs as he said its not because of plugs.. i got i changed from somwhere else.. hard to find good mechanic these days..
But i hear engine knocking sometimes when I accelerate hard, what could be the reason?
At which place this fan is situated bro
for prius i think the vents or on both sides of back seat, space between space and where door closedfor aqua vents are on left under side of back seats
fan is under those vents
