I bought a Corolla Gli 2017 facelift model in April this year. When I bought the car, its AC was not cooling well. I added more gas to the AC to make it work better, after which the compressor started showing problems like AC tripping (turned off by itself while driving). With the passage of time issue got worst and compressor is not working at all by now. I consulted with different mechanics & all also did some research on this issue and found that this was a consistent problem with the Corolla 10th and 11th generation, due to a sensor based compressor. All the mechanics have suggested me is to install a clutch based compressor from a previous generation of Corolla as it is bolt fit over 2NZ engine, however it requires a slight modification in wiring for installation of Relay. But I am hesitating this alteration as i am sensitive about car wiring. I am more intented toward the genuine sensor based aftermarket (Kabli) compressor. However, mechanics are not recommending this. I need your expert advice whether to go for Jugad method of Dumba Corolla Compressor or should install a qabli Sensor based compressor? I belong to Multan.
