Prices are variable. . Old models are less expensive. .. like 5k for 2.4 in abbotabad. .but 2003 model is like 7-8k
I recently visited the MSS (Multi Solution and Services) shop in Islamabad. This shop also repairs faulty hybrid heaters.I noticed the two reasons of heaters going bad due to user negligence were:
Hope this helps.
Nice. Where is MSS shope... location and any contact no as I want to get 110 converter fixed in
I am using two Tokyo Gas hybrid heaters. These are of medium capacity, use much less power and gas, but the problem is when the electricity is off (load shedding) you can't use them. If you have powerful UPS (with bigger batteries), you may use one on UPS as well. Mine are 23W and I use one on UPS. @sysdeamonThanks for useful info.
Its on IJP road. The shop is next to hotel situated on the right of (in-going double road towards stadium). The long way is to approach from murree road and get on IJP via Faizabad flyover and the hotel is right before the signal (Agha Shahi/Double road chowk).
Here is the contact info:Adnan Rafique (0321-5388880 , 0514856486)
Can anyone advice where to get them fixed in lahore. Bought 2 fm Quetta. One ha a problem now.
Did the translation for every one :)
these are just a type of blower,difference is that they produce heat from burning gas.and as gas is scarce these days so they are a flop.we have one at our home but no use. sure these can run on Ups but where will you bring gas?
Save is for economic gas use. So if you want to save gas and get warmth use this button
Good night is used for sleep timer.. press it and set time for sleep
Good morning is used as a wake up timer.. set tume and it ll start un morning at a set time
I have used 1.7kw and it consume 1 kg gas in 18-20 hours. Very economical and enough for 10by 9 size room
Can some 1 send 1 unit to lahore
Bro talk to multiline. I got in sialkot frm him. Good person good dealing and same as in pictures...u can giv my reference usman from sialkot purchased frm u....
Multiline is hos.nickname ?
@ thanks MarX@ nawan885 thanks for clarification of these 2 buttons.can some one plz tell the purpose of all of the above buttons as MarX has translated
You can contact to MSS Pindi , contact is given in the thread, I have got two heaters of 2.4kw from him though cargo, his name is Atif Naeem, good, cooperative and honest person to deal with.
Sent from portable device.
Great thanks will give him a try. Besides I m going pindi next week so might as well see n get in person.
As on going discussion I wanted to ask can some one clarify how much electricity this Electric heater with kind of glass rods eating up.It says 2000W on the box. With saperare buttons for the glass rods.Would it consume less if fewer rods are turned on or it will be on 2000w doesn't matter how the usage.Thanks in advance.
Sent from my Nexus Mako using Tapatalk running Android 5.0 L.
If it says 2000 Watts, it is going to use 2000 watts (or 2KW) of electricity. They simply convert electrical energy to heat of an equivalent amount Yes fewer rods = less electricity consumption
